Valve pins
Pin valve fixings notoriously carve grooves into the valve spring seats by fretting, albeit over a period of time.
This rather suggests that they are (or should be) made of something a little harder than mild steel.
(22-12-2025, 04:05 PM)Chris KC Wrote: Pin valve fixings notoriously carve grooves into the valve spring seats by fretting, albeit over a period of time.
100%
But not so hard as to be unable to withstand shocks, so a classic hard skin/tough core?
100%
Indeed. Regrettably my knowledge of metallurgy doesn't stretch much further than that.
100%
Mine should, having a degree in metallurgy, but I've forgotten much of it over the last 40 years.
As a consequence my pragmatic advice would be to buy the proper parts from a trusted Cherished Supplier
100%
I'm inclined to agree Charles. Makes you realise though that should our cherished suppliers be lost to us at any point we will be left guessing - it would be nice to think this sort of knowledge is being captured somewhere for (possible) future generations.
The A7CA Website ?
This seems to be the closest to a readily updated Austin Seven Companion.
I cannot remember- was there an updated A7C issue available ?
(22-12-2025, 11:33 PM)Tony Press Wrote: The A7CA Website ?
Yes, and updated Companion would be very handy.
I have the Special Builders Guide and Design For Competition but neither of them are as battered as my copy of the Companion, which says a lot.
Is there a reason why the valves cannot be modified to fit the pins the OP has?
Hi Peter I had a similar problem which David sorted out for me, see attached.
 Good afternoon, David
  Just a quick question, I have tried to fit the new
valve pins(
valve pins BC108C) in my valve,s and cannot get
them to fit even in the new valves I purchased,
  Question is do they come in different sizes, I can't
even press them in, although I am not sure how tight they should be, the ones I
took out I was able to just pull them out with ease.
   I don't really want to use the old pins, so I am not
sure what to do, (so ask the expert)
  Kind regards Tony
Hi Tony,
I am sorry that the valves I sent were not satisfactory. Because you had asked for 2 of them, I sent you a couple which I had that weren't part of a set of 8, and they must have been from an earlier batch. The quickest and easiest remedy is to drill out the holes to 7/64", otherwise please return them and I'll send you a couple of valves with correct (checked) holes.
I apologise for the inconvenience.
Best regards,
Da
      I took your advice and drilled out the valve
stems to 7/64" all good now, thanks again for your advice.
 Kind regards Tony.
