Can anyone tell me what grade steel I should use for making valve pins? and a likely supplier? The cherished supplier I got my new valves from some weeks ago is not able to get pins. The ones I took out of my old valves are 5 thou too big and some that I bought from another supplier are 10 thou too big! I need 0.1" diameter.
When you know the diameter you need, go to your local cycle shop and buy a spoke of the same diameter. This is what I was taught as an apprentice 1957/1960s.
John
0.1" seems large compared with what I have used in the past. My present cars do not have pins so I can't check.
I seem to remember using a cut down panel pin 65 years ago which worked with no problem!
Wouldn't it be simpler just to buy them from a cherished supplier? A7 Components have them in stock at the correct original size.
Thank you David, I did check your website and at the time I ordered the pins were out of stock with you, hence I ordered them from the Seven Workshop who's website wrongly showed that they were in stock! What diameter are the ones you have?
On my Austin Ten, I used the needle rollers from an old Hardy Spicer universal joint…worked a treat!
Thank you Ivor, I have some of those so certainly worth having a look. Otherwise I'll see if David can help.
the shaft of a pop rivet is a good option and enjoy your Christmas before its completely banned by the supermarkets and the Government Regards to all Rob.
