Engine requirement
Would anyone have a good running coil engine to suit a forward facing starter? ( 1929 / 1932 approx. )
No ancillaries required.
Collection, no problem from anywhere in the UK.
Thanks.
Chris Garner.
07774 780293
ulster29@hotmail.co.uk
Is it temporary or permanent?
Permanent Dave.
Chris.
1929-1932? Do you mean the one with the starter by the passengers feet?
John
1929-1932?do you want the engine that uses the starter mounted on top of the gearbox by the passengers feet?
john
John,
Yes, forward facing.
Chris
I always think of forward as being the front of the car- the starter in the cab is rear facing.  Or is it just me ?
Just you, Tony! It may have something to do with your location.
Some here may remember the now sadly closed Players' Theatre in London. Styled as an Old Time Music Hall, the Master of Ceremonies would ask if there were any foreign visitors in the audience. Invariably some Antipodeans were, to which the rest of the Hall would roar..." How does it feel to be the right way up ? " !!
(01-06-2025, 11:24 PM)Tony Press Wrote: I always think of forward as being the front of the car- the starter in the cab is rear facing.  Or is it just me ?
I'm with Tony on this!
The starter MOTOR in the cab faces rearwards surely, irrespective of the internal workings?
Hi Tony
If it’s any consolation I have to think twice and generally refer to them as ‘Forward facing in cab’, just to make sure.
They are forward facing as the starter pinion fires towards the front of the car!
