Car type: 1936 A7 Special
10-05-2025, 10:38 PM
(This post was last modified: 10-05-2025, 10:56 PM by falcott.)
Hi all,
I'm wondering if it's possible to restore the 1/4" threads in the crankcase back from the 5/16" threads that it is currently? I'm thinking of fitting an ally sump, and it will be a shame to drill it out to 5/16.
Or would it be better to change the crankcase?
Ta.
Cheers, Geoffrey
No they don't, if the case is already out to 5/16 or above I use bespoke brass or aluminium inserts to plug the holes if the case
Ah, okay. I'll look at getting some plugs made up, I guess. It could be an engine-out job.
Cheers, Geoffrey
How about converting to stepped studs, 5/16" down to 1/4"? That would save an engine out job.
Studs will work although they can make sump removal in-situ difficult. I would not recommend undertaking any of this work without removing the engine first.
I make a steel threaded insert from 3/8"BSF studding with a blind hole. I set it in the crankcase at the set height with Loctite. No more stripped threads. [attachment=26497]
