06-05-2025, 12:51 PM
Iam looking to mount a SU pump on a 1927-8 chummy with front tank - however space under the bonnet is tight, can anyone give some suggestions on where the best place to mount the pump is?
SU Fuel pump - mounting options
06-05-2025, 12:52 PM
Inside the footwell, above the passenger's feet.
06-05-2025, 01:06 PM
Thank you
I looked at that option lastnight, but wasnt convinced it would be easy to access should it need any maintinence.
07-05-2025, 02:30 PM
(This post was last modified: 07-05-2025, 02:36 PM by Tony Griffiths.)
(06-05-2025, 01:06 PM)JohnD Wrote: Thank youYou may find this article helpful; it tells you about fitting a 'transil' (in effect a capacitor) across the points to stop them arcing and so extend their life. https://ttypes.org/extend-the-life-of-yo...a-transil/ I'm unsure if new 6-volt pumps can be ordered with one already fitted (the plastic end cap has a cylindrical bulge if they do). https://sucarb.co.uk/su-fuel-pumps-spare...-volt.html https://sucarb.co.uk/su-fuel-pumps-spare...-kits.html The SU website looks to have been designed by a 12-year-old on acid. Looks modern and clean, but is challenging to navigate. The menu system is hopeless, and the search is useless - put in "6-volt fuel pump" and you get almost anything but. Finally, I phoned them about a different enquiry and was given excellent help: 01722-412-500
07-05-2025, 02:47 PM
I believe Burlen offer an "electronic" (points free) version but last time I looked I could only see a 12V model.
The standard SU pump is effectively maintenance-free if the car is regularly used. After long periods standing idle the points can stick (in which instance a whack with a bit of wood is all the 'maintenance' mine ever needed, to jolt them free again). I recently overhauled the pump on my Ulster rep after about 35 years in service - I only did so because I was chasing after a fault which turned out in the end to be a blocked petrol tap - so it was completely unnecessary. |
