Car type: 1936 A7 Special
Hi all, I have an anticlockwise 2:1 chronometric tachometer and a matching speedo ("Smiths" on the faces, but made in India nonetheless) and I'm intending to used them in my Special. Has anyone else done this? -- particularly the speedo. Speedos are a black art for me, I literally have no idea about ratios or anything, whether or not there is a fixed ratio for speedos. How does one match up a speedo swap otherwise?
Also, does anyone offer a tacho drive conversion from under the distributer?
Cheers, Geoffrey
Thanks, that's a start. I have Chris Gould's book and I've read about half of it. Tony Betts no longer does tachometer drive conversions so I'm still looking. And I'll look at the links that you've offered, thanks a lot.
Cheers, Geoffrey
I used my lathe - which has a known speed of rotation - to drive an unknown speedo, to see how it performed in relation to a standard speedo.
So, for example, if the input from the lathe gives 30 mph on the speedo off my car, and 60 mph on the unknown speedo, I will need a 2:1 reduction gear.
My old lathe was treadle powered, now powered by an old washing machine motor, so I've got no chance to mimic your success. But it does give food for thought. Thanks.
Cheers, Geoffrey
Hi Both
If you have a smartphone you can get a strobe app which can tell you the revs. I did this when trying to calibrate a PA speedo. I didn’t use my lathe but a drill attached to the end of the speedo cable. Using the app I was able to determine the revs of the drill at full speed. Then to see what speed that produced on the speedo. From this I found that the speedo was from a car with a 5.25 axle when my car had a 4.9 axle no wonder it was way out!
I also tried an Indian rev counter on my special with the drive taken off the bottom of the dizzy. I think that I got the ratio wrong when I purchased it but then tried to correct it via a replacement dial (scanned and photoshopped). It was never really successful and I splashed out on an electronic rev counter from Willy MacKenzie. That works very well!
Thanks guys.
Is there any lead on getting a rev counter conversion from the distributer please?
Cheers, Geoffrey
