06-04-2021, 09:02 AM
Ruairidh,
There are comments and instructions about the internal timing of magnetos here
https://www.themagnetoguys.co.uk/reversi...--magnetos
you will need to scroll down a fair way to find the relevant section.
Does the Blic in question have a fibre cam? Reducing the matter to absurdity, if the cam were almost a cylinder with just enough lift to separate the points I would think that you might find the position of the advance and retard lever had less effect - there would be a weak spark everywhere you put it. I speak in ignorance but I wonder if the problem is a worn cam?
Regards,
Stuart
Regards,
Stuart
