12-02-2025, 01:02 PM
Apologies if this has been covered before...
The project Chummy is near completion and is entered for it's first event, the VSCC Hereford trial, as a standard car, class 1a.
However, the entry regs. state:
J5.14.1 (WET BATTERIES) If located in the Driver/Passenger compartment, where a Passenger/Co-Driver is present, the battery must be situated behind the base of the Driver or Co-Driver/Passenger seat. Any wet Auxiliary batteries in the passenger compartment (including under the seat), must be enclosed in a securely located leak proof container (in the event of the battery being damaged and the car rolls over, this will stop battery acid leaking onto the occupants.) Fully wrapping the battery in heavy duty plastic is an acceptable leak proof container.
Anyone have any wisdom on this?
Is the location OK (completely standard, under the passenger seat, in a standard battery box) and how do I seal a wet battery, especially around the leads?
I know I have to put some restraining straps/bars on it to physically locate it....
