6 volt battery
Frank, you are quite right about CTEK six volt being currently unavailable, most odd. Can’t find out whether there is a production hiccup, or a policy decision not to continue with 6v.
I have two "smart" chargers/battery conditioners - one by Accumate and the other by Black and Decker. Both are switchable for either 6v or 12v.
Take a look at — Exide Vintage 80AH.  EU80-06.  From TANYA.
Excellent service and a great battery
Charles
Tayna, not Tanya....
https://www.tayna.co.uk/leisure-batteries/exide/eu80-6/
But terribly expensive delivery nowadays. They are good and I have one myself. More recently I was in need of another and am lucky that I live close to the MG owners place just outside Cambridge, so was able to get 'half' of an MGA/MGB 'pair' over the counter...
The charger I used for the trickle charge is an Acumate, but will not be using it for any long periods now.
Since the CTEK 6v charger is no longer available, I picked up a Victron Energy 6v/12v smart charger. I was advised that they are considered a direct substitute for the CTEK. Apparently it has 7 stage smart charging, maximum 1.1 amps, so it should be fine for long term storage.
(29-11-2023, 01:27 PM)Hugh Barnes Wrote: Tayna, not Tanya....
Doesn’t that separate Devon from Cornwall, as ever an eye for detail Hugh — and best wishes for Christmas etc from a fellow East Anglian
Charles
I've used a 6/12-volt Accumate from March 2019 and it's been fine. It has a proper mechanical switch for 6 or 12-volt selection and comes with both clips and a lead that can be permanently attached. It's been left on batteries for many months but, so that I reduce the number of times I swap it from car to car,  I  bought another two weeks ago for £60 on Amazon - but now on Amazon this has risen to £72, which is rather too expensive. A quick Google found one at £59.95  https://www.ebay.co.uk/itm/162711422934?...t0QAvD_BwE But, it might be that the Victron, suggested by "falco" is as good - if not better with 7-stage charging and less expensive, too: https://batterygroup.co.uk/accessories/c...WYQAvD_BwE
Just came across this 6/12 volt maintainer. No idea if any good. Anyone tried them?
https://www.chronos.ltd.uk/product/the-v...ery-saver/
.jpg   SmartSelect_20231220_185756_Facebook.jpg (Size: 347.3 KB / Downloads: 107)
(20-12-2023, 07:59 PM)Nick Salmon Wrote: Just came across this 6/12 volt maintainer. No idea if any good. Anyone tried them?
It seems to be a trickle charger with no smarts. I removed a similar device from my Special and fitted the Victron (mentioned above). I haven't had enough time to compare either charger, but the Victron inspires more confidence.
Geoffrey
