21-12-2023, 11:02 AM
Owners of Sevens fitted with the zenith 22FZ and the 22FZB carburettors are well aware of their idiosyncrasies with it's side hinged choke flap which must be released as soon as the engine starts and then nursing it for the first half mile till the engine warms up. Whilst some owners resort to flooding the carburettor which can result in excess petrol washing the oil off the cylinder walls. Knowing that most engine wear occurs on cold starting and at work all our engines were pre heated prior to starting I've long wondered if a Seven engine could be pre heated prior to start up using a long out of production accessory made by Bray. This was an electric heater installed in the lower radiator hose. I searched the internet for ages with most being way to big for a Seven being made for the North American market. Eventually I found a heater similar to the Bray for £46.91 but being of American manufacture it was 120 volts so I also needed a 240/120 volt transformer. I duly fitted the heater and tried it when the ambient temperature was 9ºC and found it heated the engine up to a just bearable temperature in 1 hour and the radiator header tank was just holdable. The heater is rated at 600 watts and will have cost me about £0.19 in electricity. While the engine fired up instantly and I could drive off without having to nurse it for the first half mile. The heater was supplied by Massey tractor Parts.
