Dynamo Repolarisation
I believe that is the method. I've done it previously when changing over from positive earth to negative earth. Just "spark" the wire 2 or 3 times on the positive battery terminal if your car is negative earth. It should be done every time you replace the battery or generator, to be honest, just to make sure that nothing is going to burn out.
Cheers, Geoffrey
Dynamo Repolarisation - by David Stepney - 20-12-2023, 11:14 PM
RE: Dynamo Repolarisation - by falcott - 21-12-2023, 08:52 AM
RE: Dynamo Repolarisation - by David Stepney - 21-12-2023, 03:53 PM
