Bewildered
I guess it's possible that an over-large clearance between an inlet valve stem and its guide could allow uncontrolled air to enter, though you would hope that there would be enough of an oil film to fill the gap. Is there any noticable side play in the valves ? Any small inlet air leak will have most effect when the throttle is nearly closed at idling and slow speeds.
One test for air leaks is to spray WD-40 in the suspect area and listen for any change in engine speed/sound as it gets sucked in and temporarily displaces the air.
Bewildered - by AustinWood - 30-11-2023, 03:08 PM
RE: Bewildered - by stuartu - 30-11-2023, 03:14 PM
RE: Bewildered - by Austin in the Shed - 30-11-2023, 03:22 PM
RE: Bewildered - by John Cornforth - 30-11-2023, 03:58 PM
RE: Bewildered - by AustinWood - 30-11-2023, 05:03 PM
RE: Bewildered - by falcott - 30-11-2023, 06:53 PM
RE: Bewildered - by Ian Williams - 01-12-2023, 06:49 AM
RE: Bewildered - by John Cornforth - 01-12-2023, 09:15 AM
RE: Bewildered - by Ruairidh Dunford - 01-12-2023, 09:35 AM
RE: Bewildered - by AustinWood - 01-12-2023, 11:37 AM
RE: Bewildered - by John Mason - 01-12-2023, 05:31 PM
