Interesting manifold and carb…
Hi
The carb looks like it is a progressive type. ( Nothing to do with 1970's music ! )
At low airflow just one barrel is used, to keep the air speed up and give good atomisation. When the first throttle butterfly gets to about 2/3 rds open, the linkage (or sometimes a vacuum capsule) rapidly opens the secondary barrel to cope with increased airflow. Both throttles end up fully open at the same point. Often the cold start choke flap is only fitted to the primary barrel.
As such, it is designed to feed all 4 cylinders.
The airflow capability is probably way in excess of even a tuned 747 cc engine, so it would be quite happy on just the primary barrel.
RE: Interesting manifold and carb… - by MartinH - 09-11-2023, 09:54 PM
RE: Interesting manifold and carb… - by John Cornforth - 10-11-2023, 08:31 PM
