Brake Cross Shaft bushes info (RP Saloon 1934)
John / Hugh
Many thanks for getting back to me so quickly and explaining how it all moves (or is supposed to!). In theory then it looks like my n/s bearing housing and bush is warn, I can work on this to make it tighter. The centre of the shaft support will be fine as it is a sliding fit between the brass liner, shaft and bearing and the housings in the centre and o/s are tight, I will just have to make another liner for the o/s. I think I will get away with using some 20swg zinc or brass.
I had to remove the shaft so drilled the rivets out, after much research on this forum understood it was the only way! the photo shows it bolted back together as I was trying the fitment and took the photo.
I think I am getting an understanding now of the tube torque as well and why it was made this way.
Many thanks both.
John.
RE: Brake Cross Shaft bushes info (RP Saloon 1934) - by John - 25-10-2023, 02:20 PM
