Brake Cross Shaft bushes info (RP Saloon 1934)
Hi John
The bearings have a semi-spherical part which is sandwiched tightly between two stamped bracket halves riveted together. This is supposed to form a self-aligning bearing, and the semi-spherical part can just about swivel to relieve any angular misalignment strain. It's not supposed to be able to rotate freely, though this can happen if the inner bearing seizes and it starts to turn and wear. If it's too loose you may need to pack out the space with shim stock, after drilling out the four rivets and replacing with high tensile fasteners. Your photo shows that the rivets have already been done.
Inside the semi-spherical part is a thin wall zinc liner, and the shaft rotates freely inside this. Zinc is tolerant of owners who forget to lubricate the bearing, but brass will work. You might have to make up your own liner, ideally this is a continuous tube but one with a slit will still work and is easier to make. It will need a "top hat" end to stop it working sideways. The fit on the shaft isn't ultra-critical but you want better than a rattling gap.
You may or may not know that (in theory at least) the torque from the foot pedal travels down the hollow outer shaft towards the centre of the car, and is then conveyed (via a weld) to the middle of the solid inner shaft to give symmetrical left/right braking. The amount of differential movement between the pedal lever and the offside rear brake lever is miniscule - I doubt if you could see it unless you added a long bar and really heaved. Nevertheless, with cable braking systems its all about the torque and tension in the various parts - any movement you see does nothing except take up slack before the real braking begins.
RE: Brake Cross Shaft bushes info (RP Saloon 1934) - by John Cornforth - 25-10-2023, 11:32 AM
