10-09-2023, 01:00 PM
I think so, yes - the lights will need to revert to 6 volt bulbs or units, obviously.
The reason for this reply is to say that the leads from the battery to the starter, and from the battery to the gearbox stud near the starter, need to be extra heavy duty to minimise the voltage drop.
If the previous owner used 'standard' 12 volt leads (whatever that is), it will not work well with a 6 volt system.
And, if not already present, separate earth leads from a common point near to the battery, to every 6 volt thing on the car, will make best use of the few volts that you have.
My car is set up like this, and I smile every time I pull the starter, it whizzes round nicely.
