pinions and spring wrappings
Friction between the leaves as they flex has a damping effect. I have always assumed that binding springs with cord was done to increase the damping effect.
Daimler springs were a beautiful pieces of engineering. There is a spacer between each leaf at the fixing point to keep the leaves apart. At the end of each leaf thear is a phosphor bronze 'top hat' section spacer. The 'brim' of the hat is the same thicknes as the spacer at the fixing point. The crown of the hat goes through a hole in the leaf above. It means there is no steel to steel contact between the leaves and each leaf acts independently. Thats what you got for paying £1,500 for a chassis with no bodywork in 1934. That would have bought you several houses!
pinions and spring wrappings - by john williams - 23-06-2023, 11:33 PM
RE: pinions and spring wrappings - by Charles P - 24-06-2023, 05:47 AM
RE: pinions and spring wrappings - by Chris KC - 24-06-2023, 09:17 AM
RE: pinions and spring wrappings - by Charles P - 24-06-2023, 09:24 AM
RE: pinions and spring wrappings - by AustinWood - 25-06-2023, 10:02 AM
RE: pinions and spring wrappings - by Chris KC - 26-06-2023, 01:24 PM
RE: pinions and spring wrappings - by Hugh Barnes - 26-06-2023, 01:46 PM
RE: pinions and spring wrappings - by Hugh Barnes - 26-06-2023, 02:40 PM
RE: pinions and spring wrappings - by AustinWood - 26-06-2023, 03:39 PM
RE: pinions and spring wrappings - by Parazine - 26-06-2023, 11:02 PM
RE: pinions and spring wrappings - by JohnD - 27-06-2023, 03:32 PM
RE: pinions and spring wrappings - by austin - 27-06-2023, 10:25 PM
