Fine bronze dust in diff oil
Hi Graham
Looking at your pictures of the excellence restoration of your car I think you should be well capable of doing the axle.
I was a structural engineer pre retirement and have no mechanical engineering or workshop training. I’ve rebuilt several axles and learnt a lot on the way but I’m convinced that luck plays a part in getting one to be quiet!  Be patient (a quality I’m not great with!) and if in doubt consult.
Woodrow, the Companion and this forum are all great sources.
Regarding the comments on the spacer from Ian and Parazine.  I very much agree.  The last axle I built was a bitsa and I had to make up the spacer.  My first attempt lasted less than 100 miles before I noticed backlash. The second using a harder steel seems to be OK at 3000 miles but I regularly check the pinion flange for any movement.
Good luck
Fine bronze dust in diff oil - by Graham O - 18-01-2023, 05:19 AM
RE: Fine bronze dust in diff oil - by Colin Reed - 18-01-2023, 09:31 AM
RE: Fine bronze dust in diff oil - by Chris KC - 18-01-2023, 11:39 AM
RE: Fine bronze dust in diff oil - by Graham O - 18-01-2023, 10:35 PM
RE: Fine bronze dust in diff oil - by Tony Press - 18-01-2023, 10:56 PM
RE: Fine bronze dust in diff oil - by Graham O - 19-01-2023, 10:28 PM
RE: Fine bronze dust in diff oil - by Dave Mann - 20-01-2023, 10:06 AM
RE: Fine bronze dust in diff oil - by Graham O - 20-01-2023, 10:55 AM
RE: Fine bronze dust in diff oil - by Parazine - 20-01-2023, 11:51 AM
RE: Fine bronze dust in diff oil - by Howard Wright - 21-01-2023, 08:40 AM
