18-01-2023, 11:39 AM
It's hard to know where to start Graham, even the 'experts' among us hesitate when it comes to axle set-up.
A certain amount of gold dust is not necessarily fatal - there are bronze bushes in the differential and also the side adjusters.
Steel particles which you can pick up with a magnet would worry me more, but if you have re-used an old CWP then a small amount of debris from re-bedding is perhaps to be expected.
It troubles me that you weren't able to strip the torque tube assembly - in particular did you check it for any end float?
The likelihood of re-using a CWP pair in a new axle and getting silent operation is fairly small. If it's noticeably worse in one direction you might want to tinker with the settings a little.
It's hard to give concrete answers, and tempting to say "give it to a specialist and have it rebuilt properly" though that is likely to cost you an arm and a leg. If it were mine I think I'd be looking around for a spare axle which I could build up nicely over a period of time as an eventual replacement.
I blew a back axle once and had the good fortune to have just passed the brow of a hill, and was able to coast 1/2 mile down to my Dad's garden gate (I'd already come 250 miles through the snow...) I don't expect ever to get that lucky again. It's not a thing you want to be trying to fix at the roadside.
