22-10-2022, 10:19 AM
Photos of another set of bonded linings that failed this month, and then destroyed the shoe itself - now removed and fitted with riveted linings.
An earlier, but similar incident, with bonded linings on a rear axle resulted in the car flipping over as the rear wheel locked solid.
I use the blue grey riveted linings with success and also the biscuit coloured riveted linings. Both work well but the biscuit type do often squeal.
Linings will break up if the rivet has been over tightened or contaminated.
