  • 1 Vote(s) - 5 Average
Speedo Cable
Thanks John, I will admit that the joint at the speedo end was a bit loose as the thread on the "nut" was too tight to enable to screw it up tight. I have since put a split washer between the inside of the "nut" and the bush that the rotating cable passes through. On th RN, its a PA type speedo that has its exit out of the bottom of the case. This now awaits a road run.
Speedo Cable - by k8207418 - 25-08-2022, 02:35 PM
RE: Speedo Cable - by Tiger - 25-08-2022, 02:39 PM
RE: Speedo Cable - by bystander - 25-08-2022, 02:49 PM
RE: Speedo Cable - by Tony Griffiths - 25-08-2022, 03:58 PM
RE: Speedo Cable - by k8207418 - 25-08-2022, 05:32 PM
RE: Speedo Cable - by Tiger - 26-08-2022, 04:51 AM
RE: Speedo Cable - by k8207418 - 14-09-2022, 06:24 PM
RE: Speedo Cable - by k8207418 - 22-09-2022, 08:00 PM
RE: Speedo Cable - by bob46320 - 23-09-2022, 05:58 PM
RE: Speedo Cable - by k8207418 - 23-09-2022, 08:18 PM
RE: Speedo Cable - by John Mason - 23-09-2022, 09:20 PM
RE: Speedo Cable - by bob46320 - 24-09-2022, 06:38 AM
RE: Speedo Cable - by Howard Wright - 24-09-2022, 08:01 AM
RE: Speedo Cable - by k8207418 - 24-09-2022, 08:47 AM
RE: Speedo Cable - by Andy Bennett - 25-09-2022, 07:11 AM
RE: Speedo Cable - by bob46320 - 25-09-2022, 03:26 PM
