I recently did the head gasket on our chummy and more-or-less did what Steve describes above. FWIW, it took four heat cycles before the nuts stopped moving, so it seems these 'ere modern gaskets compact down quite a bit! I finally did them to 20 lb/ft, using a decent Britool 4 to 24 lb torque wrench. You need a small low range one like this to be accurate at these torque settings, i.e. big torque wrenches are not accurate at low torques. If that makes sense!
head bolt torque and block
