06-04-2022, 04:01 PM
(This post was last modified: 06-04-2022, 04:07 PM by Reckless Rat.)
Before you change the steering wheel or lengthen the column, have you thought about fitting a steering knob like they have on a fork lift. I can see why you're having probs from the last photo. Lots of them available on that well know auction site.
If you're having to top the rad up that much every time something's not right. It must be going somewhere. Best check. What does the engine oil look like? Is it like mayonnaise? Other possibility is the side water branch on the block, or the rad & connections itself.
