  • 1 Vote(s) - 5 Average
New to the fold in a Special
1/ Cold oil can make things drag. Check it's not overfilled. Slipping into reverse before trying to engage 1st sometimes helps.
2/ I've made an extended column but you need to be confident TIG welding steering components. Knee surgery may be cheaper.
3/ James and Jack at TipTop are great
4/ Not my area
5/ Good luck
6/ All cars benefit from the rolling road treatment but use and play with it first and get to understand the car.
7/ Mudguards mounted on the backplates are a terrible idea for reasons of unsprung weight and durability. I'd look to lower the springs which seem quite high.
8/ It will find a level and if it stays there you have no problem, as long as that level is over the internal core
9/ Check your axle ratio. Changing to a 4 speed will do nothing since top is still 1:1. Swap the front and rear wheels and see if that helps. 5.25 or 5.125 would be the usual ratio for that build of car
Charles
New to the fold in a Special - by ECG1000 - 05-04-2022, 02:32 PM
RE: New to the fold in a Special - by Charles P - 05-04-2022, 06:35 PM
RE: New to the fold in a Special - by JonE - 05-04-2022, 06:41 PM
RE: New to the fold in a Special - by Steve Jones - 05-04-2022, 07:36 PM
RE: New to the fold in a Special - by ECG1000 - 06-04-2022, 11:07 AM
RE: New to the fold in a Special - by ECG1000 - 06-04-2022, 04:53 PM
RE: New to the fold in a Special - by Terrytuned - 06-04-2022, 08:57 PM
RE: New to the fold in a Special - by David.H - 06-04-2022, 09:22 PM
RE: New to the fold in a Special - by Ian Dunford - 06-04-2022, 09:50 PM
RE: New to the fold in a Special - by Hedd_Jones - 08-04-2022, 09:27 AM
RE: New to the fold in a Special - by Parazine - 08-04-2022, 02:17 PM
RE: New to the fold in a Special - by dickie65 - 08-04-2022, 06:08 PM
RE: New to the fold in a Special - by DavidL - 26-04-2022, 11:25 PM
