04-04-2022, 04:35 PM
That is the original arrangement for a speedy as the drawing.The only bit missing is collar retaining the spring at the front.
Steel outer ring tubular rubber seal on a bronze bush white metalled in the bore running on the steel starter dog nut.
The pressure fed Ulsters blown and unblown both had different set ups.
