Flywheel ring gears
After you have turned off the original starter ring (or removed a previous replacement ) , arrange to turn down to get at least a 5 thou interference fit. warm the ring and press on . You will now have to open up the 6--   1/4 inch holes for the clutch plate (and when assembled the 1/4  inch bolts will prevent the ring from slipping)
Apology for my previous advice. This is only valid for rear mounted starters.
Flywheel ring gears - by frequentflyer - 02-04-2022, 05:38 PM
RE: Flywheel ring gears - by AustinWood - 02-04-2022, 06:02 PM
RE: Flywheel ring gears - by Reckless Rat - 02-04-2022, 06:02 PM
RE: Flywheel ring gears - by Ken Morton - 02-04-2022, 06:29 PM
RE: Flywheel ring gears - by Howard Wright - 02-04-2022, 06:58 PM
RE: Flywheel ring gears - by Charles P - 02-04-2022, 10:55 PM
RE: Flywheel ring gears - by Bob Culver - 03-04-2022, 02:36 AM
RE: Flywheel ring gears - by dickie65 - 06-04-2022, 08:46 PM
RE: Flywheel ring gears - by Ruairidh Dunford - 06-04-2022, 09:08 PM
RE: Flywheel ring gears - by Robert Foreman - 06-04-2022, 11:15 PM
RE: Flywheel ring gears - by frequentflyer - 07-04-2022, 09:06 AM
