12-01-2022, 03:36 AM
(11-01-2022, 11:07 AM)Hedd_Jones Wrote: another one here who has seen many steel plugs. The case for the engine I'm currently messing with has all steel plugs
I stand corrected
Two brass or steel hex head screws on the offside of the crankcase along from the oil gauge take off - unscrew each carefully after wiping the area clean and use a straightened paper clip (leave a loop to stop it dropping through) to clear the jets which are just under the screws.
Also make sure you use a small paper clip- the larger one may jam in the jet
