Fuel leak from carb
Thanks, Graham, you are right.
I thought the fuel was coming out of the little hole on the top of the carburettor, but on looking again I can see it is flowing through that hole from the pool on the other side. As a test, I wrapped rags around the union and they quickly got soaked while the top of the carb remained dry.
I disassembled the union and got a very sticky bitumen like substance around my fingertips, which took ages to remove and took my fingerprints with it! I think the previous owner had had a go at sealing the joijnt. The bolt head is in a bad way so I have ordered a new union bolt from A7 Components plus a set of new fibre washers. I'll cross what's left of my fingers and hope that fixes it.
To tie up a loose end and answer my earlier question -  Burlen's Zenith rebuild set does include the needle valve.
Thanks for the help.
Fuel leak from carb - by Rubbledog - 20-10-2017, 07:57 PM
RE: Fuel leak from carb - by Zetomagneto - 20-10-2017, 08:43 PM
RE: Fuel leak from carb - by Peter Clayton - 21-10-2017, 10:02 AM
RE: Fuel leak from carb - by Ruairidh Dunford - 21-10-2017, 10:12 AM
RE: Fuel leak from carb - by Rubbledog - 03-11-2017, 06:53 PM
RE: Fuel leak from carb - by Peter Clayton - 04-11-2017, 11:09 AM
RE: Fuel leak from carb - by Robert Leigh - 04-11-2017, 11:46 AM
RE: Fuel leak from carb - by Colin Wilks - 04-11-2017, 10:50 AM
RE: Fuel leak from carb - by Rubbledog - 13-11-2017, 07:22 PM
RE: Fuel leak from carb - by Ian Wegg - 15-11-2021, 06:46 PM
RE: Fuel leak from carb - by John Mason - 15-11-2021, 10:59 PM
RE: Fuel leak from carb - by Bob Culver - 16-11-2021, 12:20 AM
RE: Fuel leak from carb - by Graham Barker - 16-11-2021, 09:25 AM
RE: Fuel leak from carb - by Ian Wegg - 19-11-2021, 06:59 PM
RE: Fuel leak from carb - by Graham Barker - 20-11-2021, 09:51 AM
RE: Fuel leak from carb - by Ian Wegg - 28-11-2021, 04:55 PM
RE: Fuel leak from carb - by Graham Barker - 28-11-2021, 08:04 PM
RE: Fuel leak from carb - by Bob Culver - 28-11-2021, 09:54 PM
RE: Fuel leak from carb - by Graham Barker - 29-11-2021, 09:06 AM
RE: Fuel leak from carb - by David Stepney - 29-11-2021, 09:40 AM
RE: Fuel leak from carb - by Ian Wegg - 29-11-2021, 03:12 PM
RE: Fuel leak from carb - by Reckless Rat - 29-11-2021, 03:19 PM
RE: Fuel leak from carb - by Ian Wegg - 31-01-2022, 12:04 PM
RE: Fuel leak from carb - by Graham Barker - 01-02-2022, 01:39 AM
RE: Fuel leak from carb - by Bob Culver - 01-02-2022, 05:31 AM
RE: Fuel leak from carb - by Andy Bennett - 02-02-2022, 03:48 PM
RE: Fuel leak from carb - by David.H - 02-02-2022, 10:34 PM
RE: Fuel leak from carb - by Bob Culver - 02-02-2022, 11:36 PM
RE: Fuel leak from carb - by Andy Bennett - 03-02-2022, 08:56 AM
RE: Fuel leak from carb - by Duncan Grimmond - 03-02-2022, 04:13 PM
RE: Fuel leak from carb - by Ian Wegg - 23-05-2022, 01:24 PM
RE: Fuel leak from carb - by Ivor Hawkins - 23-05-2022, 06:13 PM
RE: Fuel leak from carb - by dickie65 - 23-05-2022, 06:50 PM
RE: Fuel leak from carb - by Jeff Taylor - 23-05-2022, 07:19 PM
RE: Fuel leak from carb - by Ian Wegg - 24-05-2022, 07:13 AM
RE: Fuel leak from carb - by Dave Mann - 24-05-2022, 08:51 AM
RE: Fuel leak from carb - by AustinWood - 24-05-2022, 10:50 AM
RE: Fuel leak from carb - by Ian Wegg - 06-06-2022, 10:52 AM
RE: Fuel leak from carb - by Reckless Rat - 06-06-2022, 11:02 AM
RE: Fuel leak from carb - by MartinH - 06-06-2022, 01:22 PM
RE: Fuel leak from carb - by Ian Wegg - 15-06-2022, 03:12 PM
