carb problems
The carb will almost certainly be leaking because the fuel level in the float chamber is slightly too high.
I suggest you have a quick go at cleaning the bowl, check if the toggle levers work freely, check that the needle is clean and that the float is not full of fuel.
If this doesn't fix the problem and the car runs well (and the carb only leaks when the engine is off), i suggest just turning off the fuel as soon as you stop the engine.
carb problems - by Vancevr - 27-10-2021, 10:37 PM
RE: carb problems - by Dave Wheatley - 28-10-2021, 01:45 PM
RE: carb problems - by Peter Hales - 28-10-2021, 02:54 PM
RE: carb problems - by Dave Mann - 28-10-2021, 03:24 PM
RE: carb problems - by Vancevr - 28-10-2021, 04:08 PM
RE: carb problems - by Hugh Barnes - 28-10-2021, 04:32 PM
RE: carb problems - by Mike Costigan - 28-10-2021, 05:11 PM
RE: carb problems - by Vancevr - 28-10-2021, 10:26 PM
RE: carb problems - by Hugh Barnes - 29-10-2021, 08:38 AM
RE: carb problems - by Vancevr - 29-03-2022, 12:12 AM
RE: carb problems - by Dave Mann - 30-03-2022, 09:20 AM
RE: carb problems - by AustinWood - 30-03-2022, 09:42 AM
RE: carb problems - by Vancevr - 30-03-2022, 11:28 PM
