Fuel tank gauge
I had problems with my sender unit on my MK1 Ruby and the easiest solution is to carefully measure the position of the unit in relationship to the back seat floor then using a small drill to cut a hole in what you think is the centre, stick a rod through to confirm your measurements.
Then using a shortened jig saw blade cut a circle approximately 7" over the unit. once done the access is easy to remove the unit. To complete the job I then cut a thick cover of hard plastic, drilled 6 holes around the parameter and using gasket between them screw the plate onto the floor.
It's never leaked and it's allowed me to remove the unit on several occasions when problems like a leaking float have occurred. It also allows you to inspect the inside of the tank.
Problems solved Smile
Fuel tank gauge - by Tiger - 19-10-2021, 05:40 AM
RE: Fuel tank gauge - by Chris KC - 19-10-2021, 07:18 AM
RE: Fuel tank gauge - by John Cornforth - 19-10-2021, 08:27 AM
RE: Fuel tank gauge - by DaveT - 19-10-2021, 08:36 AM
RE: Fuel tank gauge - by Tiger - 19-10-2021, 08:48 AM
