Taper pin reamer
I'm trying to reassemble the Chummy bottom fan pulley after fitting a modern lip seal instead of the felt version in the starter dog housing. I have, through the kindness of a fellow forumist, now got a couple of 1/4" taper pins that can replace the rather ugly long thin nut and bolt that was previously used. To do this properly, I think I need a taper pin reamer - the existing bottom pulley has just been drilled in a couple of places to take the nust and bolt. Am I right in thinking that imperial taper pins are at a 1:48 angle and that any suitable reamer to that spec will do?
I also have a roll pin, gifted by another forumist, that I could use, so I have options.
Advice from the experts please!
Taper pin reamer - by Hugh Barnes - 18-10-2021, 12:56 PM
RE: Taper pin reamer - by Hedd_Jones - 18-10-2021, 02:05 PM
RE: Taper pin reamer - by Parazine - 18-10-2021, 04:55 PM
RE: Taper pin reamer - by Stuart Giles - 18-10-2021, 06:56 PM
RE: Taper pin reamer - by Robert Foreman - 18-10-2021, 08:31 PM
RE: Taper pin reamer - by Hugh Barnes - 18-10-2021, 08:51 PM
RE: Taper pin reamer - by Hugh Barnes - 19-10-2021, 11:04 AM
RE: Taper pin reamer - by Hedd_Jones - 19-10-2021, 12:25 PM
