Ignition coil resistance values
Hi All
I’ve tested the resistance of two 6volt coils I have and obtained the following resistance values ( both coils give similar readings).
Between + and - terminals….. 1.1 ohms
Between - or + and HT terminal…. 8.8k ohms.
I believe from research that the 1.1 ohms is a little low?  Can anyone please confirm and tell me what effect this low resistance would have?
Ignition coil resistance values - by Howard Wright - 09-10-2021, 09:40 AM
RE: Ignition coil resistance values - by Chris KC - 09-10-2021, 12:01 PM
