SM5 panel
Please All do not use WD40 on your electric contacts...WD =water dispersant.  It leaves (or used to a few years ago so still does unless formula changed) a coating on the surface when dried out.....how do I know?      story.....
At sea, large ship with whole ship many speakers and control boxes for announcements.  Each speaker box and control box had several multi-contact large relays (the type large enough that you could use a contact burnisher on to clean the contacts).  I tasked a junior officer to go round and service the, fully waterproof,  boxes.....he did so by spraying all relays with WD40.......chaos resulted with many controls/speakers not working.  He had to spend a long, long time cleaning every individual relay contact until all was again working.
There is a purpose formulated electrical contact cleaning fluid available.  For switch contacts there is also a CONTACT GREASE specially for the purpose that you smear a very thin cote on the contacts.  It prevents sparking and hence burning of the contacts.
Dennis
SM5 panel - by robinhayes25 - 10-09-2021, 09:31 PM
RE: SM5 panel - by Mike Costigan - 11-09-2021, 09:01 AM
RE: SM5 panel - by Dennis Nicholas - 11-09-2021, 10:44 AM
RE: SM5 panel - by robinhayes25 - 11-09-2021, 03:42 PM
RE: SM5 panel - by robinhayes25 - 11-09-2021, 04:55 PM
RE: SM5 panel - by Stuart Giles - 12-09-2021, 08:55 AM
RE: SM5 panel - by robinhayes25 - 12-09-2021, 07:36 PM
RE: SM5 panel - by Peter Johnson - 12-09-2021, 07:53 PM
RE: SM5 panel - by Dennis Nicholas - 13-09-2021, 11:45 AM
