10-09-2021, 03:23 PM
Thanks all
I guess I will be locking into a "new" block and possibility a new head, but at this point I have nothing to loose by trying to seal things up, the water leakage is coming from the stud with the Heli coil so I will be looking at that first, Can you buy head gaskets in bulk ? the next one will be the third, however I did not look closely at things the first time I replaced the gasket as there were some of the head studs loose which I thought was the problem
Poor old girl is getting incontinent in her old age, I will re post if I cure it with the third try
Thanks for all the help and suggestions
