camshaft locating bolt
Removal of the block allowed immediate access to the square headed cam shaft locating bolt. This turned out to be little more than finger tight. There has been much discussion of replacement and improvement of the bolt and the location it provides, for engines undergoing work. A basic response to a floppy thread would be helicoil replacement, but not at all a good idea for an assembled engine in the car. So, what response is advised? If the bolt's principal purpose is location, how strong a connection must it provide?  Would ptfe tape to minimise oil leakage, and possibly some loctite or similar to prevent movement be sufficient? Many thanks in advance.
camshaft locating bolt - by Steve kay - 02-08-2021, 09:18 PM
RE: camshaft locating bolt - by Ian Williams - 02-08-2021, 09:55 PM
RE: camshaft locating bolt - by Steve kay - 03-08-2021, 09:26 PM
RE: camshaft locating bolt - by Colin Wilks - 03-08-2021, 10:45 PM
RE: camshaft locating bolt - by SneezerUSA - 04-08-2021, 12:40 AM
RE: camshaft locating bolt - by AustinWood - 04-08-2021, 02:25 PM
RE: camshaft locating bolt - by Ruairidh Dunford - 04-08-2021, 02:29 PM
RE: camshaft locating bolt - by Ruairidh Dunford - 04-08-2021, 02:30 PM
RE: camshaft locating bolt - by Hedd_Jones - 04-08-2021, 03:59 PM
RE: camshaft locating bolt - by dickie65 - 04-08-2021, 06:49 PM
RE: camshaft locating bolt - by SneezerUSA - 05-08-2021, 01:50 PM
RE: camshaft locating bolt - by SneezerUSA - 05-08-2021, 02:53 PM
RE: camshaft locating bolt - by Bob Culver - 05-08-2021, 08:08 PM
