20-03-2021, 11:18 AM
On my RN the TDC marks on the flywheel are at about 11o'clock when the engine is actually at TDC. I'm not sure where the reference point should be on the bell housing.
I made up a little pointer for the camshaft pulley and use that instead, works every time and allows me to use a strobe for fine timing adjustments.
