Leak down test - block engine
One way is to lock the flywheel by making a finger of steel that can engage with the ring gear and be retained with one of the flywheel cover retaining bolts.  Imagine a letter "L" with a hole at the top and the base bent down slightly to lock into the teeth. (HOPE THIS MAKES SENSE).
Leak down test - block engine - by mopetta - 19-03-2021, 08:30 PM
RE: Leak down test - block engine - by Peter Clayton - 19-03-2021, 11:07 PM
RE: Leak down test - block engine - by A G Wood - 19-03-2021, 11:40 PM
RE: Leak down test - block engine - by mopetta - 20-03-2021, 07:42 AM
RE: Leak down test - block engine - by A G Wood - 20-03-2021, 10:05 AM
RE: Leak down test - block engine - by mopetta - 20-03-2021, 10:15 AM
RE: Leak down test - block engine - by A G Wood - 20-03-2021, 10:25 AM
RE: Leak down test - block engine - by Bob Culver - 21-03-2021, 08:17 AM
RE: Leak down test - block engine - by Dave Mann - 21-03-2021, 10:47 AM
