Raglan Little John lathe?
#36
Hi Bob, so far it's mainly been 1/2 BSF threads (16tpi from memory). The Riley uses a special threaded stud at the rear gearbox mount and at the rear of the chassis are two large pins that insert into the rear cross tube that have a smaller shaft and 1/2 thread on the end. That is for the rear spring shackle mounts.
The Riley since it has a torque tube and an axle that rotates in block on the springs needs a shackle either end of the spring. The lathe has been invaluable for things like spacers too. The front springs were re-built and came with new (imperial but not Whitworth) U bolts. The thread on them wasn't long enough. I have a die to extend them but then the other leg of the bolt stops you turning the die with a handle. Instead of a stack of washers 1/2 inch thick I machined up spacers from some HT steel bar. Very simple job of course but having a lathe means you can do little things like that easily and it works well and looks good.
I've also turned up replacement bushes for things and need to turn up new drive shaft U-Bolt bushes still. I also turned up some odd shaped nuts that are part of the handbrake mechanism. They were Whitworth form thread but an non standard size. I think it was 7/8 by 12 tpi? Definitely something I had to make.
I usually put up bad YouTube films about all these little things these days. Easier than taking photos and blogging.
I keep most of my tools covered in dust cloths when not being used. Old towels and sheets are good. Especially if there is any chance of grinding or saw dust going on anything.
Simon
Raglan Little John lathe? - by merlinart - 07-02-2021, 12:55 PM
RE: Raglan Little John lathe? - by Dave Wortley - 07-02-2021, 12:57 PM
RE: Raglan Little John lathe? - by Jacob Fowkes - 07-02-2021, 01:10 PM
RE: Raglan Little John lathe? - by merlinart - 07-02-2021, 02:01 PM
RE: Raglan Little John lathe? - by Charles P - 07-02-2021, 02:13 PM
RE: Raglan Little John lathe? - by bob46320 - 07-02-2021, 02:15 PM
RE: Raglan Little John lathe? - by merlinart - 07-02-2021, 02:18 PM
RE: Raglan Little John lathe? - by merlinart - 07-02-2021, 03:03 PM
RE: Raglan Little John lathe? - by Chris Garner - 07-02-2021, 04:21 PM
RE: Raglan Little John lathe? - by merlinart - 07-02-2021, 04:28 PM
RE: Raglan Little John lathe? - by Tony Griffiths - 07-02-2021, 05:14 PM
RE: Raglan Little John lathe? - by Lowespeed - 07-02-2021, 05:14 PM
RE: Raglan Little John lathe? - by Tony Griffiths - 07-02-2021, 05:22 PM
RE: Raglan Little John lathe? - by merlinart - 07-02-2021, 06:37 PM
RE: Raglan Little John lathe? - by Tony Griffiths - 07-02-2021, 07:52 PM
RE: Raglan Little John lathe? - by Bob Culver - 07-02-2021, 11:27 PM
RE: Raglan Little John lathe? - by jr2766 - 12-02-2021, 12:32 AM
RE: Raglan Little John lathe? - by merlinart - 14-03-2021, 07:36 PM
RE: Raglan Little John lathe? - by Tony Griffiths - 14-03-2021, 07:48 PM
RE: Raglan Little John lathe? - by merlinart - 14-03-2021, 07:53 PM
RE: Raglan Little John lathe? - by Steve kay - 14-03-2021, 08:39 PM
RE: Raglan Little John lathe? - by Bob Culver - 16-03-2021, 01:45 AM
RE: Raglan Little John lathe? - by Charles P - 16-03-2021, 03:28 AM
RE: Raglan Little John lathe? - by Bob Culver - 16-03-2021, 08:20 PM
RE: Raglan Little John lathe? - by jansens - 17-03-2021, 02:22 AM
RE: Raglan Little John lathe? - by Tony Griffiths - 17-03-2021, 03:43 AM
RE: Raglan Little John lathe? - by Bob Culver - 17-03-2021, 09:19 AM
RE: Raglan Little John lathe? - by Tony Griffiths - 17-03-2021, 10:25 AM
RE: Raglan Little John lathe? - by Charles P - 17-03-2021, 01:58 PM
RE: Raglan Little John lathe? - by Bob Culver - 17-03-2021, 07:04 PM
RE: Raglan Little John lathe? - by jansens - 17-03-2021, 08:31 PM
RE: Raglan Little John lathe? - by Reckless Rat - 17-03-2021, 09:32 PM
RE: Raglan Little John lathe? - by jansens - 18-03-2021, 04:21 AM
RE: Raglan Little John lathe? - by Tony Griffiths - 18-03-2021, 10:19 AM
RE: Raglan Little John lathe? - by Parazine - 18-03-2021, 10:44 AM
RE: Raglan Little John lathe? - by Dave Mann - 18-03-2021, 12:08 PM
RE: Raglan Little John lathe? - by Charles P - 18-03-2021, 12:42 PM
RE: Raglan Little John lathe? - by Ivor Hawkins - 18-03-2021, 02:42 PM
RE: Raglan Little John lathe? - by Bob Culver - 18-03-2021, 03:09 PM
