rear axle Banjo case
I have delved! there are indeed more numbers! 4  6  29 and 9/44. the pinion indeed has 9 teeth ( a couple have small chips at the inside of the base of the tooth  (if that makes sense). Pretty useable though. The other number may be 3336. So if anyone is interested there is an axle case, with torque tube and mounting together with a new (I think) CWP. sitting here (Stratford upon Avon) looking for a home ....and what I am told is an LWB half shaft.
rear axle Banjo case - by David.H - 01-03-2021, 05:36 PM
RE: rear axle Banjo case - by Stuart Giles - 01-03-2021, 07:47 PM
RE: rear axle Banjo case - by Paul Cooper - 01-03-2021, 08:49 PM
RE: rear axle Banjo case - by David.H - 01-03-2021, 08:49 PM
RE: rear axle Banjo case - by Bill Sheehan - 03-03-2021, 12:46 AM
RE: rear axle Banjo case - by David.H - 03-03-2021, 09:42 AM
RE: rear axle Banjo case - by Howard Wright - 03-03-2021, 10:08 AM
RE: rear axle Banjo case - by David.H - 16-03-2021, 04:42 PM
RE: rear axle Banjo case - by Tony Griffiths - 16-03-2021, 08:17 PM
RE: rear axle Banjo case - by David.H - 17-03-2021, 11:09 AM
