  • 1 Vote(s) - 5 Average
Q - best way to remove cam gear?
Hi Jon,
To take the shaft out the block has to come off to undo the square headed dowel. two bearing engines will drop the camshaft rollers into the sump.
Once the shaft is out you can use a block of hardwood with a hole the size of the front bearing as a support for the back of the gear while you apply your magic. You can make your own puller by using a plate over the nut with a couple of studs bolted through your lump of wood.
A three legged puller will probably break the gear teeth off ( been there done that )
Q - best way to remove cam gear? - by JonE - 16-02-2021, 08:28 PM
RE: Q - best way to remove cam gear? - by JonE - 16-02-2021, 11:39 PM
RE: Q - best way to remove cam gear? - by JonE - 17-02-2021, 07:07 PM
RE: Q - best way to remove cam gear? - by dickie65 - 17-02-2021, 07:35 PM
RE: Q - best way to remove cam gear? - by JonE - 17-02-2021, 09:36 PM
RE: Q - best way to remove cam gear? - by JonE - 18-02-2021, 08:55 PM
RE: Q - best way to remove cam gear? - by JonE - 07-03-2021, 08:31 PM
