Half shaft welding
thought id show you - I did this very job today on my special build. ill keep you posted as to how it goes. worst case if it fails ill cut the gear off bore it out and press/weld in a new bit of bar. ill cut the key seat tomorrow(borrow cutter from work)
Half shaft welding - by Howard Wright - 08-11-2020, 09:51 AM
RE: Half shaft welding - by Colin Reed - 08-11-2020, 10:28 AM
RE: Half shaft welding - by bob46320 - 08-11-2020, 11:07 AM
RE: Half shaft welding - by dickie65 - 08-11-2020, 01:30 PM
RE: Half shaft welding - by Stuart Giles - 08-11-2020, 01:53 PM
RE: Half shaft welding - by Zetomagneto - 08-11-2020, 03:22 PM
RE: Half shaft welding - by Dave Mann - 08-11-2020, 04:10 PM
RE: Half shaft welding - by Austin in the Shed - 08-11-2020, 05:17 PM
RE: Half shaft welding - by Jacob Fowkes - 08-11-2020, 07:28 PM
RE: Half shaft welding - by Howard Wright - 08-11-2020, 10:27 PM
RE: Half shaft welding - by Jacob Fowkes - 29-11-2020, 09:35 PM
RE: Half shaft welding - by Howard Wright - 29-11-2020, 09:47 PM
RE: Half shaft welding - by Jacob Fowkes - 29-11-2020, 09:58 PM
RE: Half shaft welding - by Bob Culver - 30-11-2020, 12:40 AM
