Camshaft removal problems
Three bearing camshaft removal - line the cam behind the centre bearing up so that it picks up both halves (i.e. so the cam covers the join), as cam is drawn out it will bring the centre bearing with it.
Front and centre bearing can be tight in the crankcase - heat crankcase in these areas and use a soft drift to carefully drive it all out.
Camshaft removal problems - by merlinart - 04-01-2018, 08:25 PM
RE: Camshaft removal problems - by Mike Costigan - 04-01-2018, 08:34 PM
RE: Camshaft removal problems - by merlinart - 04-01-2018, 08:49 PM
RE: Camshaft removal problems - by Reckless Rat - 04-01-2018, 08:52 PM
RE: Camshaft removal problems - by merlinart - 04-01-2018, 09:18 PM
RE: Camshaft removal problems - by Ruairidh Dunford - 04-01-2018, 09:11 PM
