Timing
If a stock camshaft, the vaves "rock" at about 7 deg ATDC. Assumig you cannot access flywheel. With manual advance can sort out running, so 25 crank degrees prior this would be a start. Half as many deg on the cam pulley which you may be avble to calibrate.
Timing - by Steve Clare - 16-08-2020, 10:18 PM
RE: Timing - by David Stepney - 16-08-2020, 11:09 PM
RE: Timing - by Bob Culver - 17-08-2020, 12:18 AM
RE: Timing - by Chris KC - 17-08-2020, 07:16 AM
RE: Timing - by Steve Clare - 17-08-2020, 01:50 PM
RE: Timing - by Dave Wortley - 17-08-2020, 02:21 PM
RE: Timing - by Tony Press - 17-08-2020, 11:40 PM
RE: Timing - by Bob Culver - 18-08-2020, 01:59 AM
RE: Timing - by Chris KC - 18-08-2020, 08:51 AM
RE: Timing - by John Mason - 18-08-2020, 09:17 AM
RE: Timing - by AustinWood - 18-08-2020, 09:23 AM
RE: Timing - by Tony Press - 18-08-2020, 11:34 PM
RE: Timing - by Steve Clare - 19-08-2020, 11:00 PM
RE: Timing - by Tony Press - 20-08-2020, 03:48 AM
RE: Timing - by Chris KC - 20-08-2020, 07:50 AM
RE: Timing - by John Mason - 20-08-2020, 09:16 AM
RE: Timing - by Chris KC - 20-08-2020, 10:41 AM
RE: Timing - by andrew34ruby - 20-08-2020, 10:05 PM
RE: Timing - by Tony Press - 21-08-2020, 02:22 AM
RE: Timing - by wild_willy - 21-08-2020, 05:35 AM
RE: Timing - by Dave Mann - 21-08-2020, 09:35 AM
RE: Timing - by Brettfcars - 01-09-2020, 07:16 PM
RE: Timing - by Steve Jones - 01-09-2020, 07:21 PM
RE: Timing - by Bob Culver - 01-09-2020, 08:27 PM
RE: Timing - by John Cornforth - 01-09-2020, 08:38 PM
RE: Timing - by Howard Wright - 01-09-2020, 09:09 PM
RE: Timing - by Zetomagneto - 02-09-2020, 09:39 AM
RE: Timing - by Tony Press - 03-09-2020, 12:31 AM
RE: Timing - by Oxford Jack - 04-06-2021, 02:59 PM
RE: Timing - by John Cornforth - 04-06-2021, 05:42 PM
RE: Timing - by Duncan Grimmond - 04-06-2021, 06:27 PM
RE: Timing - by Charles P - 04-06-2021, 06:31 PM
RE: Timing - by Howard Wright - 04-06-2021, 06:53 PM
RE: Timing - by Roger - 04-06-2021, 08:12 PM
RE: Timing - by Charles P - 04-06-2021, 08:19 PM
RE: Timing - by Peter Clayton - 09-06-2021, 08:32 PM
RE: Timing - by Hedd_Jones - 09-06-2021, 10:47 PM
RE: Timing - by Charles P - 10-06-2021, 12:00 AM
RE: Timing - by Roger - 10-06-2021, 09:32 AM
RE: Timing - by Hedd_Jones - 10-06-2021, 09:42 AM
