Tool Corner
(13-08-2020, 09:01 PM)Bob Culver Wrote: Thanks KC. I wonder if turps is plant origin pure turps and the turps substitute mineral turps, which is what as is conmmonly available here. Some older paints used to specify pure turps. I gathr in parts  of Europe solvent paints are more or less banned.?
I have done a lot of non acrylic brush painting over the decades; used to buy and resell bikes at schoool, painted 6 cars and a lot of interior house work striving for brush mark free finish although with modern paints largely despair of the latter. I scrape paint out of the brush using the rounded back edge of a knife, wash successively in used turps and finally clean turps. Brushes which have become clogged are combed with a coarse wire brush, commecing above the bristles so these are not stabbed and severed.
A lot of amateurs seem to abandon the brush at end of task!
A workshop tool I have found very useful is a quality  8 inch direct reading vernier calliper.  Instantly adjustable. Keeps the brain nimble and does not give a false sense of accuracy. Easier to hold than 6 inch. Can quickly sort dia and tpi for screws
Turpentine (which is also called spirit of turpentine, oil of turpentine, wood turpentine, terebenthene, terebinthine and (colloquially), turps) is a fluid obtained by the distillation of resin harvested from living trees, mainly pines. It is mainly used as a solvent, and as a source of material for organic syntheses.
White spirit (UK) or mineral spirits (US, Canada), also known as mineral turpentine (AU/NZ), turpentine substitute, and petroleum spirits, is a petroleum-derived clear liquid used as a common organic solvent in painting. There are also terms for specific kinds of mineral spirits, including Stoddard solvent and solvent naphtha (petroleum). Mineral spirits are often used as a paint thinner, or as a component thereof, though paint thinner is a broader category of solvent. Odorless mineral spirits (OMS) have been refined to remove the more toxic aromatic compounds, and are recommended for applications such as oil painting.
Tool Corner - by Chris KC - 11-08-2020, 05:35 PM
RE: Tool Corner - by Peter Naulls - 11-08-2020, 09:16 PM
RE: Tool Corner - by Chris KC - 11-08-2020, 09:31 PM
RE: Tool Corner - by Zetomagneto - 11-08-2020, 10:01 PM
RE: Tool Corner - by Bob Culver - 11-08-2020, 10:41 PM
RE: Tool Corner - by Chris KC - 12-08-2020, 12:37 PM
RE: Tool Corner - by Geoff Halstead - 12-08-2020, 03:21 PM
RE: Tool Corner - by Chris KC - 12-08-2020, 04:19 PM
RE: Tool Corner - by A G Wood - 13-08-2020, 12:28 AM
RE: Tool Corner - by Bob Culver - 13-08-2020, 04:08 AM
RE: Tool Corner - by andrew34ruby - 13-08-2020, 10:47 AM
RE: Tool Corner - by Chris KC - 13-08-2020, 10:49 AM
RE: Tool Corner - by Duncan Grimmond - 13-08-2020, 12:26 PM
RE: Tool Corner - by AustinWood - 13-08-2020, 01:25 PM
RE: Tool Corner - by Steve Jones - 13-08-2020, 02:44 PM
RE: Tool Corner - by Bob Culver - 13-08-2020, 09:01 PM
RE: Tool Corner - by A G Wood - 14-08-2020, 01:14 AM
RE: Tool Corner - by Tony Press - 14-08-2020, 03:58 AM
RE: Tool Corner - by Marcus Ling - 14-08-2020, 03:59 AM
RE: Tool Corner - by Bob Culver - 14-08-2020, 05:21 AM
RE: Tool Corner - by A G Wood - 14-08-2020, 10:04 AM
RE: Tool Corner - by Rogerfrench - 14-08-2020, 02:17 PM
RE: Tool Corner - by Peter Clayton - 14-08-2020, 03:19 PM
RE: Tool Corner - by Chris KC - 14-08-2020, 04:20 PM
RE: Tool Corner - by Reckless Rat - 14-08-2020, 04:29 PM
RE: Tool Corner - by Duncan Grimmond - 14-08-2020, 09:32 PM
RE: Tool Corner - by bob46320 - 15-08-2020, 07:14 AM
RE: Tool Corner - by Mark McKibbin - 15-08-2020, 08:09 AM
RE: Tool Corner - by stuartu - 15-08-2020, 08:20 AM
RE: Tool Corner - by Chris KC - 15-08-2020, 10:48 AM
RE: Tool Corner - by stuartu - 15-08-2020, 11:24 AM
RE: Tool Corner - by Duncan Grimmond - 16-08-2020, 11:07 AM
RE: Tool Corner - by David.H - 16-08-2020, 12:45 PM
RE: Tool Corner - by Stuart Giles - 16-08-2020, 01:00 PM
RE: Tool Corner - by Steve Jones - 16-08-2020, 01:11 PM
RE: Tool Corner - by Chris KC - 21-09-2020, 11:50 AM
RE: Tool Corner - by JohnD - 05-10-2020, 02:37 PM
RE: Tool Corner - by Chris KC - 13-04-2023, 11:25 AM
RE: Tool Corner - by JohnD - 14-04-2023, 10:54 AM
RE: Tool Corner - by Chris KC - 14-04-2023, 11:17 AM
RE: Tool Corner - by JohnD - 18-09-2023, 04:12 PM
RE: Tool Corner - by Duncan Grimmond - 18-09-2023, 04:47 PM
