19-07-2020, 05:08 PM
Filler would not be a long term solution.The radius of the wing looks a bit out so I would try a sand bag with a wooden domed mallet to try and dress out the wing to fit a bit closer.The only other alternative would be to cut the body and weld in another piece to make up the gap .This is a bit more complicated to do on this part of the body and some distortion is inevitable.I have done this on my Rp saloon and it has worked out fine although a skim of filler or lead is necessary to give a good finish.
