Bending Clutch Levers
(30-06-2020, 01:12 AM)squeak Wrote: All the repair pegs I have seen were screwed in from behind until the fingers were level and then the excess ground off flush. Various methods of preventing the pegs from subsequent movement  were, center punch, soft solder, locktite. If your fingers are new and still identical, and your pivot pins in the posts are new I would  review your repair peg heights rather than bending.
This has to be the way to go, explore this fully first -from an engineering perspective, if you have all new fingers, they are identical, the fault is else where . it'd be far easier to control material removal from the peg than to control a bend. Getting the bend wrong means new fingers again . getting the pin wrong just means screwing a bit more through
the use of a dremmel with mounted point grinding wheel would help you access the pin without the need to remove the posts
Bending Clutch Levers - by John P - 29-06-2020, 03:42 PM
RE: Bending Clutch Levers - by Nick Turley - 30-06-2020, 01:11 AM
RE: Bending Clutch Levers - by squeak - 30-06-2020, 01:12 AM
RE: Bending Clutch Levers - by Tim Watkins - 30-06-2020, 11:41 AM
RE: Bending Clutch Levers - by Colin Wilks - 30-06-2020, 05:06 PM
RE: Bending Clutch Levers - by Hedd_Jones - 30-06-2020, 08:54 PM
RE: Bending Clutch Levers - by AustinWood - 30-06-2020, 10:00 PM
RE: Bending Clutch Levers - by Hedd_Jones - 30-06-2020, 10:09 PM
RE: Bending Clutch Levers - by Nick Turley - 30-06-2020, 11:00 PM
RE: Bending Clutch Levers - by John P - 30-06-2020, 11:15 PM
RE: Bending Clutch Levers - by Parazine - 01-07-2020, 08:49 AM
RE: Bending Clutch Levers - by John P - 01-07-2020, 09:36 AM
RE: Bending Clutch Levers - by Parazine - 01-07-2020, 09:44 AM
RE: Bending Clutch Levers - by Stuart Giles - 01-07-2020, 10:21 AM
RE: Bending Clutch Levers - by Nick Turley - 01-07-2020, 10:29 AM
RE: Bending Clutch Levers - by John P - 01-07-2020, 01:39 PM
RE: Bending Clutch Levers - by squeak - 01-07-2020, 01:58 PM
RE: Bending Clutch Levers - by Ivor Hawkins - 01-07-2020, 02:17 PM
RE: Bending Clutch Levers - by AustinWood - 01-07-2020, 02:49 PM
RE: Bending Clutch Levers - by Steve Jones - 01-07-2020, 02:59 PM
RE: Bending Clutch Levers - by John P - 01-07-2020, 06:42 PM
RE: Bending Clutch Levers - by Howard Wright - 01-07-2020, 07:58 PM
RE: Bending Clutch Levers - by John P - 13-07-2020, 05:15 PM
RE: Bending Clutch Levers - by Ruairidh Dunford - 13-07-2020, 05:58 PM
RE: Bending Clutch Levers - by squeak - 13-07-2020, 11:47 PM
RE: Bending Clutch Levers - by Howard Wright - 14-07-2020, 07:34 AM
