Lucas SM5 switch panel spare parts
(10-06-2020, 09:35 PM)TomHunt Wrote: Personally I would say a rapid protoype wouldn't be a great way to go, mostly the prints aren't very robust and breaks down in UV. Surface finish would also be a bit rough. Moulding over a brass insert gives a good strong result that comes out as a finished product.
Hi Tom, I've just seen your post, very interesting regarding the moulding -looks impressive. Your comment does confirm my experience with the surface finish of 3D printing, that could certainly be fixed with some fine abrasive, don't know about the potential longevity with UV; there seem to be a bewildering range of filaments available nowadays.
A good mate who does a lot of CAD stuff at work offered to have a go at replicating the lever by drawing it up and 3D printing. Here's a couple of photos of the first print -as it's just a try out he used whatever filament was in the printer.
[Image: 50057110068_be5ef07cfc_z.jpg]
[Image: 50057109463_aed7b81f21_z.jpg]
Fortunately, while that was going on, a member on here (thanks so much) sent me a lever. Identical to the SM5 lever at the front but turned out to be different at the rear, the 'london transport logo' dimensions were both larger and further forward on the lever. Quite an interesting machining job to reproduce the SM5 register without using CNC equipment.
[Image: 50057677681_023fc1e1a7_z.jpg]
Very pleased with the result, just need to build up the rest of the car now!
[Image: 50057928052_8d0c3bd4a8_z.jpg]
BTW, Mark, who did the drawing/3D printing did the drawing on a publicly accessable site -TinkerCAD- so if anyone wants to print one or edit the drawing and print, let me know and I'll get you the URL
RE: Lucas SM5 switch panel spare parts - by Stuart Giles - 29-06-2020, 11:29 AM
RE: Lucas SM5 switch panel spare parts - by JonE - 06-10-2021, 10:28 AM
RE: Lucas SM5 switch panel spare parts - by JonE - 07-10-2021, 08:27 AM
