Fuel system cleaning
(11-06-2020, 07:55 PM)morrisminor Wrote: I've started to clean the fuel system on my Ruby,  it having broken down due to muck in the system,  I've drained the fuel tank,  couldn't believe the muck that came out,  blown through the fuel line,  I'm going to clean carb and fuel pump,  I've pushed wire down the inlet in the tank,  I can push it about 9 inches,  is that about as far as you can push ?
I'm going to put a inline fuel filter before the pump to help,  can anyone suggest anything else from experience.
I'm trying this to save taking the tank out !
Thanks guys
couple of thoughts based on my experience — firstly it’s a good idea to drain your tank outside ie not in the workshop. Just a precaution. Re inline fuel filter, if you fit one of the conventional plastic ones — check your sender unit is well earthed. I suspect the fuel line is an earth normally but your filter will possibly upset this.
Fuel system cleaning - by morrisminor - 11-06-2020, 07:55 PM
RE: Fuel system cleaning - by David Stepney - 11-06-2020, 09:15 PM
RE: Fuel system cleaning - by Derek Sheldon - 12-06-2020, 02:11 PM
RE: Fuel system cleaning - by Charles Levien - 12-06-2020, 02:51 PM
RE: Fuel system cleaning - by Derek Sheldon - 12-06-2020, 05:16 PM
RE: Fuel system cleaning - by Duncan Grimmond - 12-06-2020, 06:06 PM
RE: Fuel system cleaning - by morrisminor - 12-06-2020, 06:48 PM
RE: Fuel system cleaning - by Derek Sheldon - 12-06-2020, 07:03 PM
RE: Fuel system cleaning - by John Cornforth - 12-06-2020, 07:42 PM
RE: Fuel system cleaning - by morrisminor - 12-06-2020, 08:53 PM
RE: Fuel system cleaning - by Charles Levien - 13-06-2020, 08:15 AM
RE: Fuel system cleaning - by Duncan Grimmond - 13-06-2020, 08:55 AM
RE: Fuel system cleaning - by morrisminor - 13-06-2020, 11:53 AM
RE: Fuel system cleaning - by Charles Levien - 14-06-2020, 10:01 AM
RE: Fuel system cleaning - by David Stepney - 14-06-2020, 05:46 PM
