RESTORING a 50s Seven 750 SPECIAL
#44
Jon its a race car it has an electric water pump as long as its moving it does not need a fan, I have done one with a Ricardo head with a 180 shape hose back to the same type of header tank as long as a water pump is fitted there is no problem with temperature or flow the water capacity is 5ltr. The electric pump comes on with ignition if you stop with a hot engine there is a water pump override switch so you can run the pump to cool the engine. Terry.
RESTORING a 50s Seven 750 SPECIAL - by JonE - 19-04-2020, 12:04 PM
RE: RESTORING a 50s Seven 750 SPECIAL - by Alan - 19-04-2020, 01:09 PM
RE: RESTORING a 50s Seven 750 SPECIAL - by JonE - 19-04-2020, 01:46 PM
RE: RESTORING a 50s Seven 750 SPECIAL - by JonE - 20-04-2020, 07:17 AM
RE: RESTORING a 50s Seven 750 SPECIAL - by JonE - 23-04-2020, 12:52 PM
RE: RESTORING a 50s Seven 750 SPECIAL - by Renaud - 23-04-2020, 05:47 PM
RE: RESTORING a 50s Seven 750 SPECIAL - by JonE - 23-04-2020, 10:13 PM
RE: RESTORING a 50s Seven 750 SPECIAL - by JonE - 26-04-2020, 08:49 AM
RE: RESTORING a 50s Seven 750 SPECIAL - by Renaud - 26-04-2020, 10:19 AM
RE: RESTORING a 50s Seven 750 SPECIAL - by JonE - 27-04-2020, 07:08 PM
RE: RESTORING a 50s Seven 750 SPECIAL - by JonE - 28-04-2020, 12:35 PM
RE: RESTORING a 50s Seven 750 SPECIAL - by JonE - 29-04-2020, 07:53 AM
RE: RESTORING a 50s Seven 750 SPECIAL - by Renaud - 29-04-2020, 08:04 AM
RE: RESTORING a 50s Seven 750 SPECIAL - by squeak - 29-04-2020, 09:31 AM
RE: RESTORING a 50s Seven 750 SPECIAL - by Alan - 29-04-2020, 09:34 AM
RE: RESTORING a 50s Seven 750 SPECIAL - by JonE - 29-04-2020, 05:46 PM
RE: RESTORING a 50s Seven 750 SPECIAL - by JonE - 08-05-2020, 07:26 PM
RE: RESTORING a 50s Seven 750 SPECIAL - by JonE - 09-05-2020, 02:28 PM
RE: RESTORING a 50s Seven 750 SPECIAL - by JonE - 11-05-2020, 06:00 PM
RE: RESTORING a 50s Seven 750 SPECIAL - by JonE - 11-05-2020, 07:40 PM
RE: RESTORING a 50s Seven 750 SPECIAL - by Terrytuned - 11-05-2020, 09:04 PM
RE: RESTORING a 50s Seven 750 SPECIAL - by JonE - 11-05-2020, 10:37 PM
