25-02-2020, 06:30 PM
Hi Martin,
The C35A Dymamo disc is
33.14mm diameter,
.92mm thick
Approx 4mm dome.
The wire circlip is made of 1.32 diameter wire with a hooked end to aid removal.
I just happen to have on on the workbench at the moment.
It should be easy to make a new disc but the wire retaining clip would be a bit more difficult.
I hope this helps.
33.14mm diameter,
.92mm thick
Approx 4mm dome.
I hope this helps.
